I understand that this may be incredibly vague, but based on current container ships, does anyone have an idea of how much power a 50,000 TEU (TwentyFoot Equivalent Unit) container ship might require?
- For propulsion (assuming a single screw)
- For auxiliary power
And how much fuel (assuming petroleum)would have to be carried onboard?
https://maritime-executive.com/editorials/50000-teu-the-future-or-not
The Algeciras-class container ships have just under 24,000 TEU of capacity, and are powered by MAN 11G95ME engines rated at 101,300 SHP. I'm not sure if this 50,000 TEU ship's power would simply be double that of the Algeciras ships.
n.b.
While the TEU is not itself a measure of mass, some conclusions can be drawn about the maximum mass that a TEU can represent. The maximum gross mass for a 20-foot (6.1 m) dry cargo container is 24,000 kilograms (53,000 lb). Subtracting the tare mass of the container itself, the maximum amount of cargo per TEU is reduced to approximately 21,600 kilograms (47,600 lb).
UPDATE: Conceptually, the main engine would be a MAN "14G108ME-C" with a 1080 mm bore and 4800 mm stroke. At 70 RPM, total output is 10.8 MW per cylinder with 151.2 MW at the shaft, plus a 10 MW shaft generator, and mean piston speed is 12 m/s.
Emissions reduction is accomplished with direct water/methanol injection, low-pressure SCR, and a sodium hydroxide wet scrubber.
Assuming a 5300mm centre-to-centre distance for the connecting rods, peak-to-peak amplitudes for the secondary imbalance are 574.537mm overall, consisting of 574.301mm second-order, 8.2246mm fourth-order, 0.235618mm sixth order, and 8.43819μm eighth-order.
