In the physical sciences (which are physics, chemistry, astronomy, materials science, etc.), we learned that the uncertainty is +/- the smallest unit (which is 1) of the last significant figure if the uncertainty is not given in a recording of data. So, if we have a digital measuring device that measures to the nearest millimeter, has a manufacturer's stated uncertainty of +/- 1 mm, and gives a reading of 914 mm, then it will obviously be recorded as just "914 mm".
So, if a yard stick is specced to a length of 914 mm +/- 1 mm (I know, the tolerance is too loose for a measuring device, but this is just an example problem) does the true length actually lie somewhere between exactly 913 mm and exactly 915 mm, or may it stray outside even those numbers if higher precision is used? For example, if go down to the micrometer, is the uncertainty actually +/- 999 μm or +/- 1,499 μm according to the rules of significant figures? If we measure the same yardstick using a micrometer, is the reading guaranteed to be somewhere between 913,001 microns and 914,999 microns, or is it instead only guaranteed to be somewhere between 912,501 microns and 915,499 microns, respectively?
