Suppose the problem of the subsonic flow over a simply-supported rectangular plate as bellow. According to the assumptions of incompressible, inviscid and irrotational flow, and using perturbation potential function, the applied fluid pressure on the plate is as below:
$$P=\sum_{m=1}^{M}\sum_{n=1}^{N}\rho\frac{ab}{\sqrt{{n^2a^2+m^2b^2}}}[W_{mn}(x,y)\frac{d^2q_{mn}(t)}{dt^2}+2U_{\infty}\frac{\partial W_{mn}(x,y)}{\partial x}\frac{dq_{mn}(t)}{dt}+U_{\infty}^2\frac{\partial W_{mn}^2(x,y)}{\partial x^2}q_{mn}(t)]$$
Where $a$ and $b$ are the length and width of the plate, respectively, $\rho$ is the fluid density, $U_{\infty}$ is the fluid speed in x direction and $W_{mn}(x,y)$ are the free vibration mode shapes of the plate defined as:
$$W_{mn}(x,y)=sin(\frac{m\pi x}{a})sin(\frac{n\pi y}{b})$$
which m and n are natural numbers. The total generalized fluid force can be calculated as:
$$F_{ij}=\int_{0}^a\int_{0}^bW_{ij}(x,y)Pdxdy$$
which i and j are natural numbers similar to m and n. Substituting P from the first equation into the above equation one can get the following equation: $$F=M\frac{d^2q(t)}{dt^2}+C\frac{dq(t)}{dt}+Kq(t)$$ where M, C and K are mass, damping and stiffness matrices, respectively, expressed as follows: $$M_{ij}= \frac{\rho ab}{\sqrt{{n^2a^2+m^2b^2}}}\int_{0}^a\int_{0}^b W_{mn}(x,y)W_{ij}(x,y)dxdy$$ $$C_{ij}=\frac{2\rho ab U_{\infty}}{\sqrt{{n^2a^2+m^2b^2}}}\int_{0}^a\int_{0}^b\frac{\partial W_{mn}(x,y)}{\partial x}W_{ij}(x,y)dxdy$$ $$K_{ij}=\frac{\rho ab U_{\infty}^2}{\sqrt{{n^2a^2+m^2b^2}}}\int_{0}^a\int_{0}^b\frac{\partial W_{mn}(x,y)^2}{\partial x^2}W_{ij}(x,y)dxdy$$ As you can see because of the term $\sqrt{{n^2a^2+m^2b^2}}$ none of the above matrices are symmetric. What is the physical and mathematical meaning of non-symmetric mass, damping and stiffness matrix?
