Been looking for a COTs carbide/ HSS cutting tool for milling standard 37 deg flare fluid ports, but am struggling to find anything applicable. Since these are common enough fluid fittings, I figure there has to be something out there.
Does anyone know what this type of tool would be called?
Acceptable specs are either J1926-1 (flare, NOT SAE o-ring boss) or AS5202. Specifically I'm looking for size -4, 37 deg female AN.
Essentially, I'm interested in a tool that can be used to machine a feature into a part that is similar to this (see photo) in a single in-and-out operation. Thread tapping would happen separately.
Before anyone suggests an adapter... it HAS to be this size and it HAS to be a milled port. So milling an NPT port and installing an adapter unfortunately does not work
