14
It is a bit unclear whether this is the "user manual" or the "service manual", the latter may have only been used by service people, but nevertheless, why would it go through the specifics of the SCART connector, naming the purpose of each pin?
Yes, it goes through all of the internals of the TV in insane detail, but the SCART connector is not something invented for this TV or by this company (JVC). It's just a standard, external interface.
For me, all these years later, it was interesting to read about, but what purpose could it have had for anyone using or repairing the TV?
SCART is SCART.
It's just a connector, which doesn't change between TVs, am I right? Or have I misunderstood something?
Were there many different "versions" of SCART or something? That seems like it would defeat the purpose of having a standard like that.
SCART pin assignment
  • 9
    $\begingroup$ "SCART" and "standard" in the same paragraph... $\endgroup$
    – pipe
    Commented May 28, 2022 at 7:09
    $\begingroup$ AnecodtaI: I remember having to look up which pin to artificially set high to get one of my devices to show up on screen (20 years ago). I vaguely recall pin 9, but looking at your picture it must have been pin 8. Could've been 9V on pin 8. We didn't have the SCART standard at home (or reliable internet to look it up), but we did have a TV manual. That's why. $\endgroup$
    – Mast
    Commented May 28, 2022 at 14:25
    $\begingroup$ @pipe OP said "a standard", not "the standard". $\endgroup$
    – Rosie F
    Commented May 29, 2022 at 8:01
  • 4
    $\begingroup$ Our 80's home stereo system came with a full set of detailed schematics. Anyone could have built a perfect clone just based on the owner's guide (the only thing missing were PCB layouts). Those were the days of the "right to repair" that we're now slowly reinventing. $\endgroup$
    – TooTea
    Commented May 29, 2022 at 18:57
  • $\begingroup$ The problem with the implementation of a standard is limited by the designers understanding of the standard and the percentage they implement. $\endgroup$ Commented May 30, 2022 at 3:31
41
There was no Internet then. The only source of most of that information was through the manuals and if it wasn't published you could be stuck. Many of us made up adaptors and cables and this information would have been quite useful.
As far as I know, not all devices had all pins connected. The manual gives the minimum information required to establish which SCART features have been implemented.
  • 7
    $\begingroup$ Confirmed, there were different "versions" of the SCART connector; I guess there no device ever to support the full feature set offered by the SCART standard. The TV shown in the OP is already quite unusual, as it offers an anlog RGB input. $\endgroup$
    – Klaws
    Commented May 28, 2022 at 9:54
    $\begingroup$ My Sony TV could do full RGB scart giving my Wii a pristine picture. Not all devices could do that. $\endgroup$ Commented May 28, 2022 at 20:03
  • $\begingroup$ There were a LOT of home computer enthusiasts and a fair percentage of DIY builders and a LOT of incompatible systems and using the house TV instead of a monitor was a thing. $\endgroup$ Commented May 30, 2022 at 16:54
    $\begingroup$ @Klaws "The TV shown in the OP is already quite unusual, as it offers an anlog RGB input." Analogue RGB input on a TV should be common as it was required for external subtitle boxes, an early use for SCART. Also RGB inputs are straightforward to provide on a colour TV as it already has RGB circuits internally. SCART peripherals may not have had RGB if it wasn't relevant e.g a VHS VCR would only have had composite video (pins 19 + 20) as the picture quality didn't require RGB. A DVD player would provide RGB on its SCART output. $\endgroup$
    – Graham Nye
    Commented May 30, 2022 at 22:38
  • $\begingroup$ @Graham Nye Thank you for the "reprimand". Seems I had all the "special" TVs back in the days. Yes, I had actually wondered why none of the TVs I had to deal with had analog RGB inputs (as you mentioned, that would have been very little effort to support). Well -- in Germany, subtitles came (and still come) via Teletext (Videotext in German), so no need for subtitle boxes, so maybe the RGB option was omitted in some cases to save a Deutschmark. I did, however, own a video monitor with RGB input. And how I loved the dexterity game, plugging the connector without bending the flimsy fins! $\endgroup$
    – Klaws
    Commented May 31, 2022 at 14:16
Also consider that manuals back then were the only source of information outside going back to the shop or to a dedicated repair shop.
So the manuals were made more durable than the one-page paper sheet with a URL on it. My parents stored all the manuals on a bookshelf, along with the Big Dictionary and other common reference books. An extreme example is computer manuals from the days of DOS - solid ringbinders and slip cases.
If a booklet is just stapled paper then it has four A5 sides for each A4 leaf used. So if the information to be published is a multiple of 4x A5 pages you've filled it. But if you go over that by 1 then there are three blank pages that must be in the booklet.
It gets worse if you have a glued-spine, which was quite common for the range of 40-200 pages. A "folio" or fold would be four leaves of A4, giving 16 sides of A5. The paper's there, may as well put something on it because it has to go through the printer and folding/binding.
( I use A4 and A5 as examples. It was just as likely to have A3 paper and A4 sized pages, or similar other standard sizes. )
SCART dates from 1977 and was mandated in France from 1980 to 2015.
The standard was subject to several amendments and at least 2 major revisions, approved by CENELEC on 13 November 1988 (EN 50049-1:1989) and 1 July 1997 (EN 50049-1:1997).
So the manual is also documenting the current standard implemented in this device at the time.
