I've made the following oddity in Solidworks:
All the dimensions are known except for the top part. This is probably because this was done using the Lofted Boss/Base feature. The Loft profile goes (top-view) from the big circle at 90° to the small circle at 180°.
Now I know what the part should look like, I want to copy the exact dimensions so I can replicate this effect with proper tools that do work with adjustable values and dimensions.
How would I got about that? It's basically a feature between two circles, so a combination of a Spline and Sweep seems like a good start. Getting the values right would probably take some work but is doable (the thin part of the neck is roughly 10mm). But then? Do I need a helix of sorts to get that twist in? I have no idea on how to continue from here.
