I have the following truss and I want to calculate the reactions using the flexibility method
Using this method means that I need to break this indeterminate system into a determinate system and two redundant systems (with the reintroduced member force) in this case. In other to obtain these subsystems, I need to release members (or reactions).
Say I want to release 2 of the members from the truss, how do I know which members to release?
Do the members that I remove have to be the members that are connected the supports? (ie to use the compatibility equation).
So a follow up question is where does the compatibility equations apply? (Only at the supports?)
I have tried to remove 2 members that are connected to the supports but using a software it tells me that the structure is unstable. (with full hinges applied etc)
I then proceed to remove other 2 members, they are stable, but they are not connected to supports. Does the compatibility equation apply here?
