We have a few underground tanks with only the manholes visible from the outside. All tanks are cubic-shaped. How can we accurately measure the dimensions (depth,length and width) of the tanks? Are there any types of equipment to do that? The tanks store wastewater and it won't be possible for anyone to enter it through the manholes.
    $\begingroup$ "Dipstick" could even be a stone tied to string for depth. $\endgroup$
    Apr 30, 2022 at 7:25
  • $\begingroup$ @SolarMike Dipstick is probably not an option as it is a septic tank. Any other equipment ( laser/sonar etc ) without touching the liquid to get the depth? $\endgroup$
    – dInGd0nG
    May 1, 2022 at 8:04
Depth can be measured by dipstick whether partially full or not.
A range of ultrasonic "tape measures" in a Google image search.
Distance from the manhole to the walls should be measurable by laser or ultrasonic "measuring tape" provided there is some air space at the top of the tank.
  • $\begingroup$ Dipstick is probably not an option as it is a septic tank. Any other equipment ( laser/sonar etc ) without touching the liquid to get the depth? $\endgroup$
    – dInGd0nG
    May 1, 2022 at 8:04
  • $\begingroup$ @dInGd0nG you ask for "laser/sonar etc" did you read the answer? What do you think ultrasonic does? $\endgroup$
    May 1, 2022 at 8:21
  • $\begingroup$ @dInGd0nG, your question doesn't specify those restrictions. $\endgroup$
    – Transistor
    May 1, 2022 at 8:23
The problem with most handheld measurement devices is that you need someone to enter the manhole, for example to hold the laser distance meter against one wall to measure the distance to the next. To get an accurate measurement of the conditions above the water level, contact a surveying company to do a LIDAR scan. Explan the situation to them, the will need a way (possibly they need to build a jig to do so) to lower the scanner down the manhole and keep it stationary at one place. Talk to the surveying company if you need a 2D or 3D scan. A skilled CAD operator should be able to turn the cloud of points gerneated by the scan into a 3D-Model or drawing.
The measure the depth beneath the wastewater surface, you will need a dipstick. Any measurement device will have to be lowered below the liquid surface, so make it low cost => Dipstick.
Be aware that wastewater channels are Ex-hazard zones an you will likely not get an ATEX approved LIDAR device (if such a thing even exists). Do a risk assessment, consider bringing a gas sensor and maybe equipment to ventilate the tank before measuring.
  • $\begingroup$ "... you need someone to enter the manhole, for example to hold the laser distance meter against one wall to measure the distance to the next." Why not measure from the manhole to each wall with ultrasonic or laser? $\endgroup$
    – Transistor
    May 2, 2022 at 12:24
  • $\begingroup$ @Transistor All laser sensors I've seen so far need to be held in the hand. If you measure from the manhole, you need to build a jig that holds the laser in one place to get real results. Without beeing down in the manhole, you don't know if you measure perpendicular to the walls, if your are actually measuring wall to wall distance. I'm sure all these problems can be overcome, but I think at this point renting a LIDAR is the better and simpler solution. $\endgroup$
    – mart
    May 2, 2022 at 14:04
