I am working on a problem for research that is about material choices. I was wondering if the following rearrangement of Euler columns would be a valid way to check to see if a material exists for a given critical load and moment of inertia:
Original Equation:
$P_{cr} = \frac{\pi^2EI}{l^2}$
Where $P_{cr}$ is the critical load, $E$ is the young's modulus, $I$ is the moment of inertia, and $l$ is the length (note that I am omitting different end conditions).
Possible Reformulation to check for a valid young's modulus:
$E = P_{cr}\frac{l^2}{\pi^2I}$
