I’m building a friction wheel drive electric Unicycle.
Something like this; enter image description here
My question is how much torque should the friction wheel drive motor have considering the total mass of unicycle including rider is 100kg?
Additional information;
I'd like the unicycle to go at speeds of up to 6 miles per hour, and climb up hill a slope of 45 degrees.
The unicycle would not be self balancing, the rider would have to balance it themselves by using throttle and brake.
The rider would be tilting themselves forward at an angle of 45 degrees.
  • $\begingroup$ If you were pedalling, how much power would you need for the speed you want? Friction wheel wil need to deliver the same. $\endgroup$
    Apr 23 at 17:08
  • $\begingroup$ I edited the question and changed the slope angle from 30 degrees to 45 degrees, and also added that the rider would be tilting themselves forward at an angle of 45 degrees too. $\endgroup$ Apr 24 at 10:23
    $\begingroup$ A friend had a friction drive ( gasoline) bike ( Travis) in 1950. We thought the friction drive was poor. $\endgroup$ Apr 24 at 15:15
The speed is not really important, how fast it reaches that speed (acceleration) is relevant.
To move 100kg up a ramp of 30 degrees with a speed of 6miles
$V=6*\frac{1600m}{1mile}=9600mh=2.6m/s$
$$2.66*sin(30^ \circ)=1.33m/s$$
The vertical component of force, Fv
$$F=mgsin(30^ \circ)=100*9.8*(1/2)=490N$$
$$P=F*V=490N*1.33m/s=651.7*1.1(friction and loss)=716Watts$$
Let's assume 10%friction and loss, the torque of the monocycle wheel (big wheel) is
$$T=490*1.1*26*0.025=175Nm$$
The torque of the friction wheel is proportional to the radius of the friction wheel divided by the radius monocycle wheel multiplied by the torque of the big wheel.
$$T_{frictionwheel}=175.175\frac{R_{frictionwheel}}{R_{monocicle}}$$
Edit
the rider has to tilt his body same as the angle of slope to make equilbrium. but this doesn't have any effect on the torque.
however if the rider want to accelerate with an acceleration of $a , $ he needs to bend an addition angle of $ arctan(a/g) $ with g, being gravity acceleration and the friction wheel torque has to be increase by the same ratio.
also as to the slope of 45 degrees just plug in $mgsin(45)$ in the above calculations.
  • $\begingroup$ I edited the question and changed the slope angle from 30 degrees to 45 degrees, and also added that the rider would be tilting themselves forward at an angle of 45 degrees too. $\endgroup$ Apr 24 at 10:19
    $\begingroup$ @RayyanJaved so change the angles and redo the calculations. What else do you expect? $\endgroup$
    Apr 24 at 10:25
  • $\begingroup$ Will the rider tilting forward add any more torque than calculated? $\endgroup$ Apr 24 at 11:40
  • $\begingroup$ When running at constant velocity the rider would have to tilt to that angle which puts the centre of gravity of rider and cycle over the point of contact of the wheel with the slope. This may not be 45°. $\endgroup$
    – Transistor
    Apr 24 at 22:17
  • $\begingroup$ @Transistr, i mean the same thing. at constant speed the CG of the bike and rider must pass through the contract point. we need to have the height and posision of the saddle to be more exact. $\endgroup$
    – kamran
    Apr 25 at 0:09
