The following outline is inspired by something I noticed today and couldn't figure out.
It shows what I guess is a fairly common generic situation - an upper floor masonry partition wall supported by a beam, with further loads (ceiling/next floor joists?) supported in turn by it.
I've tried to make it generic. So the supported wall (grey) is toothed into the adjacent wall (brown, left) as is common for partition walls, and the beam (red) is supported by that wall and another internal partition wall (brown, right). Ignoring s/w and eccentricity, it's a pretty simple beam situation, where the beam supports just a wall and whatever is on the wall. I haven't given values or dimensions as I'm interested in how it's assessed, rather than some specific solution.
What has me puzzled is, it's not clear what governs the parts of these loads supported by the beam. There is load spreading, full-height support by the left hand wall, and the corbel angle to consider.
The toothed support and corbel angle suggest only a small part of the load will be supported by the beam. None of the arbitrary top loads, and maybe only a third of the wall masonry, are within the corbel angle. Can that be right? Does one reckon to include all of the topmost loads? or part of them? or none of them (and just the masonry within the corbel angle)? What is the right way to think about it?
How can we tell which loads to include as beam loading, when loads spread throughout a wall before that wall is supported on the beam?
My thinking so far
In theory, I've got the following points:
- The loads at the top of the wall will load-spread at (say) 45 degrees within the wall. They are likely to present as a UDL due to spreading, even if they began as point loads.
- Much of the load will be taken by the left hand wall, as "our" wall is toothed into it throughout its height. (It's not like it is supported by the beam alone.) So some of the load is taken by the adjacent wall => not the beam.
- Looking at the beam alone, the corbel angle of 60 degrees (yellow triangle) suggests the beam load includes none of the loads at the top of the wall, and only about a third of the wall's weight, because those are all ultimately outside the corbel angle and will be supported by the two masonry walls directly. Can that be right?
