I am working for a small domestic home appliance manufacturer and we are looking at ways to reduce our appliance's carbon footprint.
Currently we use a lot of die-casted zinc-aluminum alloy (Zamak, usually), and we are wondering if there are more sustainable sources or processes to obtain a part with similar properties (i.e.: mechanical, weight ("heavy feeling")). If the part is visible to the customer, then we typically paint the part which is also not very eco-friendly.
We are looking at aluminum or PCR-ABS with PVD coating, but aluminum prices are soaring and the PCR-ABS doesn't have the same robust feeling as a metal part.
Examples of similar parts are dishwasher door handles, oven handles, metal handles for electric kettles.
  • $\begingroup$ A more descriptive title would be " alternatives to zinc die cast". The zamaks' are basically zinc with a few pre-cent Al , and possible Cu, Pure zinc ( eg prime western) dissolves steel rapidly and the small alloy addition prevents the zinc from dissolving the steel injection dies. I very much doubt you will find a polymer anywhere close to the 7 density of zinc. Lead is the only metal that is as cheap ( and not as strong). $\endgroup$ Mar 28, 2022 at 23:33
  • $\begingroup$ Wood? definitely renewable $\endgroup$
    – Tiger Guy
    Mar 29, 2022 at 15:42
