Here is the question: A pontoon of length L is ballasted so that the density in the bottom half is twice that in the top half.
a) Find the maximum value, smax, of the specific density, s, for which the pontoon will float in water.
b) Find the positions of the centre of buoyancy, CB and the centre of gravity, CG, when s=smax.
I have already completed part a and found that $S_{max} = \frac{2}{3}S$ using my diagram:
. $S = 1$ to make sure the pontoon is floating and $1$ to make sure $S$ will be the max.
Okay now part b), the center of bouayncy isnt too difficult, which is just the centroid of the displace volume, in this case, $\frac{H}{2}$
Now I am not sure how to find the center of gravity. Apparently, I have to take moment about the top of the body. Which results into the following.
Can someone please explain the solutions? Where are the forces? Why are we multiplying the mass by the height? Even if we have the weight instead of mass, wouldn't this be downwards?
