I have a small DC motor/gearbox unit and the spec sheets is shown below. All* the units are measured at the gear box output, so 100 RPM would be 3,000 at the motor.
I'm using it as a generator so am putting mechanical power (which I have calculated) into it, and, using a resistor as a load, getting electrical power out (measured with an oscilloscope).
In order to see how things are working, theory Vs practice, I need to know how efficient my motor/gearbox is.
Firstly I understand these curves are designed for use as a motor, so I'm A) using the motor as a generator, and B) driving the gearbox from the wrong end. So comments on what affect this will have are welcome.
Anyway, to get the efficiency from the supplied curves, I'm doing this:
A) drawing a horz line across from my speed (75rpm) in the top right chart
B) where that intersects the speed line (green, blue?) draw a vert line. Gives me about 50 oz-in
C) on the bottom left chart go vert from the 50 oz-in mark
D) where that intersects the efficiency curve look across horz to the c 18% figure.
Am I doing this correctly?
- bar the torque vs power curve which shows input power
