I'm looking for what I might be missing in trying to align the fence on my bandsaw. I have a Laguna Tools 18|Bx 3HP 220V 18″ Bandsaw, specifically a MBAND18BX2203. When I let them know the alignment was off, they were super cool and sent me a new aluminum fence. However, my vertical alignment is way off.
the problem
The problem isn't the fence itself.
nice flat surface and fence
I'm worried then about the knuckle and rail. Hitting the rail with calipers, I see that I'm off by a bit of a mm (0.68, or 12.93 at one side and 13.61 mm at the other), but that doesn't explain the difference. (See pic below)
I'm curious if anyone else has had this problem and how I can adjust the knuckle's vertical dimensions or rail.
The fence is also not horizontally aligned.
ok -- sorry I missed this. The manual addressed this pretty well. enter image description here
