I'm working on an application that rotates a cylindrical mass in a manner to compensate for roll in a boat. The roll of the boat is rather slow so I was thinking it might be possibly to simply use a PID loop to control the angular position of the mass with a load encoder and feed roll data from a sensor to it as a set point or trajectory.
I was also thinking maybe it would be better to use a cascade control scheme with the angular control using a position sensor/encoder for angle control and then an outer loop around the roll sensor. My thinking is that this would more accurately track the roll.
Maybe feedforward is also a solution, but again, with roll not "in the loop" I'm thinking it won't be as accurate. What its the thought process to determine an optimal control scheme? What would you recommend?
Thanks
