The products of the reaction are useful. Renewables like solar power can be used for the electrolysis of brine.
I don't understand why petrochemical companies are not using it as a scrubber?
Sign up to join this communityThe products of the reaction are useful. Renewables like solar power can be used for the electrolysis of brine.
This is because the manufacture of NaOH requires energy, and if that energy comes from fossil fuels, then the net gain of the overall process is either zero or less than zero.
Net-positive CO2 sequestration requires finding a natural source of the chemical reactant. One such source is the found in the rock formation called an ophiolite (specifically, the component peridotite), which naturally pulls CO2 out of the air as it weathers and decomposes.
Ophiolite is normally found deep in the earth's crust but there happens to be a very large deposit of it on the surface in the country Oman. It may be possible to mine the peridotite out of it and use that to offset CO2 production from burning fossil fuels.
Total worldwide demand for sodium carbonate is about $0.6\,\mathsf{Tmol}/\,\mathsf{y}$. Total worldwide carbon dioxide emissions from fossil-fuel burning and cement production are about $800\,\mathsf{Tmol}/\,\mathsf{y}$. So either this approach would have a negligible effect on carbon dioxide emissions, or it would leave you with a lot of unwanted sodium carbonate to dispose of.
MEA is the most common scrubber solution the remove CO2, its been used for many decades. Calcium hydroxide is also common, but then there is solid calcium carbonate waste. Long ago, before I retired, there was more sulfur in flue gas so the carbonate was contaminated with calcium sulfate. I am not up to date on current technology but I am sure you can find information looking at "flue gas scrubbing"; it has been used a hundred years for various purposes in various industries. As has been pointed out, it does cost money.
