I am a noob engineering student. I want to design a coaxial gearbox that takes an input shaft that rotates reciprocally (clockwise then counterclockwise) and increases the speed of rotation unidirectionally to a coaxial output shaft.
For example, a hand-crank is turned 180 degrees clockwise then 180 degrees counterclockwise repeatedly while rotating a flywheel only clockwise. However, the torque from the hand-crank in both directions must be used to increase the speed of the flywheel in a single direction. In other words, both the clockwise and counterclockwise torque must be transmitted smoothly to the flywheel. Hopefully that makes sense. Thanks!
