Quick google search will return either 6000 series (6061 more specifically), or 3003
However with so many option and each having it's own benefit, I still haven't make my decision
What I am looking for is the one with the most resistance to corrosion in alkaline aqueous environment, other parameter can be neglected (strength, workability, etc)
Any suggestion?
  • $\begingroup$ When you say "alkaline" is that like a bleach solution or just bleach or full blown sodium hydroxide? $\endgroup$
    Jan 3, 2022 at 9:13
  • $\begingroup$ Yes, sodium hydroxide $\endgroup$
    – poalsd
    Jan 3, 2022 at 9:15
None, 3003 is listed as better general corrosion resistance but it makes little difference which aluminum alloy is used in a seriously corrosive.
  • $\begingroup$ Well. So 3003 better than the rest aluminum in terms of corrosion resistance? Should i choose that over the others? $\endgroup$
    – poalsd
    Jan 3, 2022 at 23:34
  • $\begingroup$ @poalsd I think what he's saying that best is so close to worse that it makes little difference what you choose. What are you doing? Experimenting with aluminum and sodium hydroxide? Or do you actually need the aluminum to maintain integrity? $\endgroup$
    – DKNguyen
    Jan 4, 2022 at 4:39
  • $\begingroup$ Yes , at pH 8 there are some differences , at pH 11 there is no significant difference. $\endgroup$ Jan 5, 2022 at 16:29
