I'm looking to design a cascaded controller to transform a BLDC into a servomotor. The system has a motor current controller in the inner loop, which is controlled by a torque controller, which is controlled by a an angular speed controller, which is controlled by a position controller.
The system is extremely dynamic and I'm looking at position settlement times smaller than 0.02 s, so the time constants of the inner loops are much faster than this.
I'm fairly new to controller design, so I'm looking at which control techniques I should use. I came across many techniques and don't know which one I should prioritize, in order to guide my learning process.
At first I thought about classical techniques such as a PID controller designed by Root Locus and Frequency Response techniques. Do you think these will be enough? If so, which technique would be better for this application and why? Should I consider state-space instead?
Are these techniques appropriate, or I should resort to other modern techniques such as fuzzy logic, optimal control, predictive model control, etc?
