I am an aeronautical engineering student and at university with a group of friends we are are working on building a rocket aimed at getting past the Karman Line (boundary to space).
We will be starting with smaller rocket launched and building our way up to the final rocket. I am thinking about what the best method would be to scale our design. We could build a small liquid engine rocket and as we go on to build larger rockets, we would use the same liquid engine rocket but it would bigger in size or the alternative would be to use multiple small ones and multiple nozzles.
In short, what is a more scalable design, one large nozzle or multiple small nozzles?
I can understand that with using multiple smaller engines would be better since we would have tested, and launched them previously. Whereas if we were just to make the liquid larger, we wouldn't have launched them before.
I am not sure if I have explained my question clearly. Do comment if you want any other clarifications.
FYI: we are using a bi-propellant engine, with no turbo pump and regenerative cooling.
