22
How do ball bearings last? Most bearings in a standard hub (bottom of the image) are not actually taking a load. Only the single ball that happens to be at a particular location while spinning takes 100% of the load. If the bearings were cylindrical (top of the image) supporting a rolling plate, it would be slightly better, but not by much.
Regardless of the load (in a bike hub), and even if it's just cyclist+bicycle, that the area is infinitesimally small would suggest that the stress skyrockets towards infinity. And that's before even talking of the higher loads in a car's bearings.
How do ball bearings (in a bike hub) not crack from a load concentrated on an infinitesimally small point?
ball bearings stress load
This is a sequel question to a question I just asked on bicycles.SE about how much grease I should use after I overhaul bike hubs—whether I should put so little to keep the wheel spinning freely with minimal drag, or put so much that water ingress would be unlikely (the red areas in the image).
11
  • $\begingroup$ On a roller bearing as the inner cage is free then the load will be taken by two balls. $\endgroup$
    Dec 22, 2021 at 18:06
  • $\begingroup$ @SolarMike Okay, so assuming that all ball bearings have the same diameter to the nearest nanometer, two balls will take the load (or are they actually not entirely rigid?). Still, two times zero is zero. $\endgroup$
    – Sam
    Dec 22, 2021 at 18:09
  • $\begingroup$ What are you assuming is zero? $\endgroup$
    Dec 22, 2021 at 18:11
  • $\begingroup$ @If you take a sphere and deposit on any other surface with any different curvature, then the area of contact, from a pure math point of view, is zero. It is just a point. Of course engineering has more to say than this purists' view. $\endgroup$
    – Sam
    Dec 22, 2021 at 20:16
  • 4
    $\begingroup$ So, a point contact can support zero load based on your analysis. Obviously not true in the real world so the area of contact must therefore be larger. $\endgroup$
    Dec 22, 2021 at 21:05
5 Answers 5
36
Nothing is rigid, the raceways and the ball in a ball-bearing are no exception. The contact area deflects and accommodates the ball in a small contact surface, not a point.
Also, the balls take the load in groups.
The digrams are from SKF ball-bearings.
shear and compression
cantac area group of balls
  • $\begingroup$ Fascinating. That indeed is the only explanation. They are far harder than, say, an inflated basketball, but under load they still deform and expose a significant area for load bearing. $\endgroup$
    – Sam
    Dec 22, 2021 at 20:00
  • 7
    $\begingroup$ yes, yes, not an SE novice here. I was just editing on the bicycles.SE forum to illuminate both sides with the lights shining from the other. $\endgroup$
    – Sam
    Dec 22, 2021 at 20:13
  • $\begingroup$ I think the particular form of elastic deformation in the ball is called a "Hertzian contact". $\endgroup$ Dec 22, 2021 at 22:25
  • $\begingroup$ it's a bit complex. the ball gets warped towards the rear of contact patch while creating a small sag in the raceway. the sag looks like an uneven pit. sharp edge on the front with lagging tail on the rear constantly moving on the raceway and heaving back. $\endgroup$
    – kamran
    Dec 23, 2021 at 0:42
17
TL;DR: ball bearings deform due to Hertzian pressure and therefore distribute the load
However, the reason balls (rolling elements) don't easily crack is the ductility of the material (and to some lesser extent the treatment of the material)
The Deformation of the bearing balls due to Hertzian pressure contributes to the distribution of the loads and only delays failure. However the mode of failure is not affected. So for a high enough pressure you could have a load that will lead to failure, but you wouldn't expect it to crack.
Distribution of loads due to Hertzian pressure deformation
Every material in deforms when a load is applied. The ball bearing although they are very stiff and seem non-deformable they experience small deformation, due to what its called Hertzian pressure. The deformation is what causes distribution of the loads to neighboring balls.
The contact surface between a ball bearing and a contact surface is:
Figure: contact between a ball bearing and a raceway with a lubricant (source Springer)
The end result (exaggerated) is the following:
| enter image description here |enter image description here|
Figure: Exaggerated deformation of elastic bearing (left) and corresponding stresses (right) - (Source bearing news)
the red ball bearings are the one in contact. Obviously the central one carries the highest load compared to any other single ball. However, the load is distributed at different bearing (see image below)
Also, the load on the central bearing significantly reduces compared to others as the load increases (because deformation is not linear).
So there is a significant distribution of the loads (however that does not explain by itself why the balls don't crack because for a high enough load there could be a case where the loads are such that the bearing will fail)
Compressive failure of Ductile vs Brittle material.
When a material is compressed, depending on its ductility it will behave differently.
Figure: Compressive brittle and ductile failure (source:pmpaspeakingofprecision)
In the brittle failure there is a plane at 45 degrees (where the maximum shear strength is observed that a crack develops).
In the failure of ductile material under compression, there will be a lateral increase of the ball (like squashing a tennis ball), and eventually when the maximum shear stress of the material is reached cracks will appear radially (see above).
Steel is a ductile material and it is expected to fail in a ductile manner. However, bearing very rarely fail by cracking of the load. By the time the reach a more brittle mode failure, the shape is such that the bearing will not be able to rotate anymore and it will become stuck. This in turns causes additional stresses from torsional moments etc which are unpredictable.
Additionally ball bearings treated (heat and also mechanically sometimes) to create prestresses that create a compressive stress on the surface which tends to arrest cracks. Because there are those compressive stresses, they tend to arrest any cracks (which usually develop from the surface).
Figure : (source [Marcelin Benchea](Residual stress versus depth along the contact axis ))
    $\begingroup$ The last point is the most important ; residual heat-treatment stresses. Bearing fatigue life essentially doubled when New Departure developed the heat-treatment. $\endgroup$ Dec 23, 2021 at 15:22
Bearings of different designs have point contact or line contact.
The roller bearings have a curve line of contact - only have to take one apart to see the wear path on the inner and outer race.
As for 1 ball taking all the load - that won’t happen as the load will cause the balls to move allowing the smaller distance between inner and outer race - that amount of movement is limited by the ball guide holding all the balls.
They are very strong, and it is not quite a point as there is some elastic strain. Rolling element bearings are nominally HRC 62, roughly 300,000 psi yield. And have residual compressive stress at the surface that partially offsets tensile stress. You need to be in the secret society of metallurgy to understand the heat-treat process that develops the residual stress. They are 52100 low alloy steel , chrome with 1 % carbon but that doesn't help much. Lubrication is a different story which I do not know but have read that too much grease can be a problem.
Ductility-- of the ball, the race, and the cone-- is indeed a key to the ball not cracking. My experience with bicycle bearings is of having the ball, the race, or the cone show some pitting, and/or for the race to show spalling or cracking. Usually during a repack I found that the balls were in flawless condition. From all this I came to the belief that (a) there was an advantage to the spherical shape (b) the balls were the hardest component, and (c) the relative advantage of the balls improved after some break-in on the race and the cone, as they developed "tracks" in them.
