Can a car ac compressor be used as a Hydraulic pump ? Does it require some modifications to do so or is it impossible to begin with and the compressor can't handle the oil?
No, the clearances, compression ratio and valves are not designed for that use.
If you want a hydraulic pump then use a power steering pump, now available in two flavours mechanical ie engine or belt driven and electric.
I would say definitely not. Pumps like that are designed specifically for their application, and changing the working fluid is not what I would call a minor change. It's possible you could hook it up and get it to run poorly in a fashion, but be prepared for it to break at any moment, so whatever you need the hydraulic pressure for would be at risk. It would be much easier to buy a small hydraulic pump, or better yet a hydraulic jack unless you need a lot of fluid displacement.
- Air compressors work by compressing air, a gas.
- Hydraulic pumps work by pumping hydraulic fluid, a liquid, which is not compressible.
Attempting to run hydraulic fluid through an air compressor will most likely burst the compressor.
