I work for a medium-sized civil engineering firm (about 200 employees) that is trying to improve its BIM capabilities. Specifically, it would like to improve data sharing data become compliant with ISO 19650. We have started managing data in a common data environment (CDE) like Autodesk BIM360 and enforcing an ISO 19650 naming convention. This leads to documents with names like:
101-BIMicon-CD-L2-DR-A-A40-010-R1.pdf
Even if you understand the naming convention, it is very difficult to know what the document contains. For this reason the company is proposing that each project has a document register (typically an Excel spreadsheet). The register is manually updated whenever a document is created, either by the author or the BIM manager. To find a documents, you use the register like an index: find the file name using your description then search for the document on the CDE.
To me, this process negates all the advantages of BIM: time savings, fewer mistakes, and automation of basic tasks. Mistakes are made in the creation of files and time is wasted looking for the correct document. We use a range of proprietary formats and the added admin puts off those of my colleagues who most need it.
How can we improve this? My gut feeling is this should be reasonably easy to automate.
