I saw this video of adjusting conveyor belt tension and I wonder how the adjustment actually works mechanically https://youtu.be/eKkJN7WkCfw?t=152
As you can see, each of the two sides can be adjusted by turning a corresponding bolt. Considering the roller is fitted on a solid shaft, wouldn't pushing one side forward cause the shaft to bend? How does the roller and its shaft change orientation when the shaft and the roller are solid?
