I know that efficiency depends on compression ratio(CR), NA engines always has higher CR than turbos,so how turbo engine can have better efficiency?
$\begingroup$ Consider consumer-model cars which have turbos which switch on and off. Compression ratio is always the same, but the absolute compression goes up (and fuel content), leading to greater power. But not greater efficiency. $\endgroup$– Carl WitthoftNov 5, 2021 at 12:57
The compression ratio (CR) is defined as the ratio of the volume of the cylinder and its head space (including the pre-combustion chamber, if present). So the compression ratio only deals with volumes.
However, the basic idea of a turbocharger is to force more air into an engine. With a traditional ICE, air can only be drawn in up to atmospheric pressure (1 atmosphere = 1 bar absolute). The turbocharger increases the pressure that comes inside the volume, so effectively you get more fuel inside the chamber, as a result you have more power per stroke.
So there is more power in turbo engines, however, I don't think that efficiency (in the sense of fuel economy) is necessarily better in turbo-charged engines. To my understanding car manufactures downsize the engine displacement and add a turbocharger which has the same power and 10-30% more fuel economy.
The reason for the increased fuel efficiency is that in the same volume you can get more fuel, and therefore the thermal density is greater. That means that during combustion there is higher temperature achieved, so essentially the thermal efficiency is better. Additionally, due to the more thermal energy per stroke, waste energy is recovered in the exhaust and feeding it back into the engine intake. By using this otherwise wasted energy to increase the temperature of air, it becomes easier to ensure that all fuel is burned before being vented at the start of the exhaust stage.
$\begingroup$ Why then all auto brands go for Turbo engines nowdays and stop producing NA engines? $\endgroup$– Jurgen MNov 5, 2021 at 10:14
$\begingroup$ I am not sure how you define efficiency. You mean fuel economy or more power out of the fuel? there is a subtle difference there. $\endgroup$– NMechNov 5, 2021 at 10:17
$\begingroup$ I mean efficinecy is how much fuel is converted to mechanical energy that drive the car..so higher efficnecy= better fuel economy $\endgroup$– Jurgen MNov 5, 2021 at 10:22
$\begingroup$ @JurgenM I update the answer. Hopefully, it makes sense now $\endgroup$– NMechNov 5, 2021 at 10:24
$\begingroup$ You first state that turbo dont have better fuel economy ant then explain why it has 10-30% better fuel economy.. that is contradictory $\endgroup$– Jurgen MNov 5, 2021 at 10:30
Efficiency is improved but it isn't obvious from the equations
From wiki
- Process 0–1 a mass of air is drawn into piston/cylinder arrangement at constant pressure.
- Process 1–2 is an adiabatic (isentropic) compression of the charge as the piston moves from bottom dead center (BDC) to top dead center (TDC).
- Process 2–3 is a constant-volume heat transfer to the working gas from an external source while the piston is at top dead center. This process is intended to represent the ignition of the fuel-air mixture and the subsequent rapid burning.
- Process 3–4 is an adiabatic (isentropic) expansion (power stroke).
- Process 4–1 completes the cycle by a constant-volume process in which heat is rejected from the air while the piston is at bottom dead center.
- Process 1–0 the mass of air is released to the atmosphere in a constant pressure process.
Wiki also shows the derivation of the Otto efficiency using the above diagram. That is the source of your original diagram.
Turbochargers increase the power of an engine because spark-ignition engines have power relative to the amount of air we can get into the cylinder. More air = more power.
Adding a turbocharger to the process changes the diagram, but not in obvious ways. P1 is increased, but P2 may not be since we have a max pressure to prevent excessive detonation (knock). The ideal Otto diagram isn't a good place to analyze this. The turbo air charge is also often cooled to allow more mass flow into the cylinder, which means there is heat loss from the system during O-1, further complicating the issue. All this means that we can't use the derivation of efficiency used to produce your graph.
That said, we know empirically that turbocharged engines are more efficient. The key reasons for this are:
- We extract work from the waste heat (exhaust stream) to compress the incoming air charge
- For the same automobile (not the same engine) we can build a smaller engine to provide the same power, which means less friction loss.
This is not true. Sometimes the exact same engine is fitted to different cars, some with a turbo some without. The particular example I am thinking of is a Diesel, however.
Adding a turbo to an existing engine will increase its power and efficiency. We know this to be true empirically, because otherwise why would anyone bother? Increase in power occurs because we get more air into the engine. Getting more power from an engine while keeping friction the same clearly means better efficiency.
Another source of increase in efficiency (in fact, theoretically the main one) occurs because in most engines, the exhaust pressure is higher than the inlet pressure (as a result of the same mass of gas being trapped in a cylinder at higher temperature) hence there is pressure that would be otherwise wasted, and this can be used in a turbo to compress the air going into the engine. More pressure in the inlet stroke means more power in the power stroke.
I say "most engines", because there is another way round this issue - the Atkinson cycle. In Atkinson cycle engines the inlet valve is deliberately closed late, allowing some of the inlet mixture to exit the engine. This gives a (comparitively) shorter compression stroke and a long power stroke, meaning the exhaust pressure is fully used. The "compression ratio" for compression on an Atkinson engine can be made the same as a "typical" engine while the power stroke has a longer compression ratio. The result is that Atkinson cycle engines have no excess pressure in the exhaust stroke and do not benefit from turbochargers (in fact they have no excess pressure to drive a turbocharger.)
Now, as I mentioned, sometimees the exact same engine is fitted to different cars, some with a turbo some without. But the only example I could think of was Diesel. There's a reason for this. Having too much pressure in a gasoline engine causes premature ignition. An engine that's designed to be used with a turbocharger doesn't necessarily need the same compression ratio to achieve the same efficiency, because the turbocharger takes care of that. In fact, the compression ratio may need to be deliberately reduced in order to prevent premature ignition (known as "knocking"). You still end up with an engine with better power/weight ratio, which will help with overall vehicle efficiency.
For the same reason that a compound expansion steam engine was more thermally efficient than a single expansion steam engine operating at the exact same pressure.
You have to make the cylinder walls out of something, and steel is the normal choice. Steel conducts heat. Some of that heat conduction is essential to stop the engine from melting. There is a trade-off between how hot you can run an engine - hotter being more efficient all else being equal - and how much heat you have to dump through the cylinder walls to let you operate at that peak temperature. Dumping heat through the walls lowers efficiency.
For a normally aspirated mid compression engine, about 30 percent of the heat is transferred to the coolant. Most of this is a dead loss to efficiency, and the thing to realize is that much of it is a function of the reciprocating engine's basic layout. A lot of the heat runs down the cylinder wall from the head to the skirt. This heat flow is lossy because the cylinder pressure is lower further down the cylinder. There are engines that are made to very carefully control the heat flow at very constant loads. But for a versatile engine, the design will move a lot more heat down the cylinder wall than is necessary most of the time.
Not all turbos increase engine efficiency, but the ones that do so work by reducing the heat loss from the iron to the coolant. Let's say you have a n.a. 10:1 compression ratio iron block and the cylinder is square - 3" dia and 3" stroke. If you turbo the thing so that you only need 7:1 to get the same peak temp and pressure, you can shorten the stroke and shorten the cylinder liner. The cylinder operates at a higher average temp because the bottom temp is higher, and the heat flow down the cylinder is greatly reduced even though the heat flow across the cylinder into the coolant is the same keeping the peak temp the same. It turns out that the turbo system can be designed to lose less heat than you save in the sleeves. A full-on efficiency turbo on a near-constant load application such as a big genset can reduce direct and coolant heat losses by about 2 percent. They can also slightly reduce the heat loss from the exhaust.
So for a normally aspirated engine, the thermal breakdown might be 33% exhaust, 33% coolant and air loss, and 34% work. The turbo version might be 32% exhaust, 31% coolant, and 37% work if the block is reworked but the peak conditions are the same. It's easier cost-wise to justify this on diesels.
One other comment. In boats, the prop power absorption curve goes as rpm^3. So when cruising at part throttle, the engine is running at very low pressures. A turbo can help match the torque and power curve of the engine to the shape of these propeller load curves and improve cruise efficiency by better matching engine performance at cruise while still providing the same peak power.
Historically, turboexpanders were invented for efficiency. They converted supersonic exhaust streams from aircraft piston engines to slower, quieter conditions and shafted the power over to the prop shaft. The efficiency bump really comes from the expansion side of the turbocharger. Using the power to drive a charging turbine is one option, and it really doesn't have much of an efficiency impact.
$\begingroup$ Maybe you can add turbo engine as it smaller it has less internal friction,this is also one way how achieve better efficiency $\endgroup$– Jurgen MNov 7, 2021 at 6:30
$\begingroup$ Friction heat is removed by the coolant ;) But the change in friction due to turbocharging is really small. Cylinder friction amounts to only about 3% of the coolant heat load to begin with. Crank friction and valve train friction together are similar. They don't change much. $\endgroup$ Nov 7, 2021 at 12:38
$\begingroup$ So biggest gain in efficiency is because turbo work at higher combustion temperatures and lose less heat in enviroment? The main contribution why turbo car has better mpg is ligther car? Where is in this story thermal efficiency vs compression ratio? $\endgroup$– Jurgen MNov 7, 2021 at 13:40
$\begingroup$ No, the expansion turbine recovers energy from the exhaust stream. If you compress at 10:1 in a normally aspirated engine, you can only expand to about 10:1. You can jigger this a bit with valve timing, but that starts to get squirrely over a range of rpms and loads. With an exhaust turbine, the exhaust backpressure isn't wasted. Now if you want to, you can shaft the exhaust turbine to a pressure charging system. You don't get independent control of charging and backpressure, but it is a tidy setup. Big engines will have multi-stage charging and multi-effect heat recovery systems. $\endgroup$ Nov 7, 2021 at 13:55
$\begingroup$ These can operate independently to some degree. $\endgroup$ Nov 7, 2021 at 13:55
