I have a Nema23 that has a 1.8 degree stepping resolution. The motor has a GT2 pulley attached on the rotating element. This GT2 pulley is coupled with another pulley, using a belt, which is directly around the shaft of a lead screw.
I'd like to increase my stepping resolution, I already use micro-stepping, so I was thinking of using a 60 tooth pulley on my lead screw and a 20 tooth pulley on the stepper. Such that a step from my motor would result in less rotation of the lead screw. But what I am curious about is how will this affect the torque experienced by the motor? Will I be able to lift the same load, or maybe even more? Are there any drawbacks to such a modification?
  • $\begingroup$ PS- you may know this, but can't hurt mentioning - while you can readily get a 32x-128x microstepping driver now, and it will help extend the range of speed, as well improve smoothness at low speed, by creating a good sine-wave voltage or current profile, it probably won't give you nearly that multiple of an improvement in the position resolution and esp. accuracy when standing still. That's the driver. Wrt/ the belt, drawback is complexity, including however you plan on controlling belt tension. $\endgroup$
    – Pete W
    Nov 4, 2021 at 22:20
  • $\begingroup$ you don't tell us the current sizing of the pulleys so it's hard to say how this will change. $\endgroup$
    – Tiger Guy
    Nov 4, 2021 at 23:17
Yes. you're right. Your stepper motor will produce 3 times more torque, 3 times more resolution.
And 3 times slower angular speed on the lead screw.
  • $\begingroup$ After reading this again I am a little confused. Are you saying that the stepper motor rotating at a fixed speed (frequency A) will now experience 3x less torque when doing a task with this 3:1 gear ratio versus before? Or are you saying the opposite? $\endgroup$
    – Feynman137
    Nov 6, 2021 at 1:09
    $\begingroup$ it will experience less torque. the smaller the power wheel the smaller torque it feels. but the other pulley will turn slower. $\endgroup$
    – kamran
    Nov 6, 2021 at 1:26
