This question is about the following two energy balance equations (assuming no energy input/output):
- Bernoulli: $\frac{p}{\rho} +\frac {v^2}{2} + zg = const.$
- Steady-flow: $u +\frac {p}{\rho} +\frac{v^2}{2}+ zg = const.$
So as everyone knows the Bernoulli equation only applies to incompressible fluids in steady state. When comparing the Bernoulli equation with the Steady-flow equation, the former seems to be a special case of the latter when the internal energy is kept constant. But the steady-flow equation applies to compressible gases as well, so I conclude that all we need to do to apply Bernoulli for compressible flows is to consider the internal energy term. But searching for Bernoulli for compressible flows online seems to result in much more complicated equations, so I am confused and unsure if I am missing something.
