Basically I have nearly 1000 files. I want to edit a dimension which is labeled D2@Sketch 10. Assuming that the name can be a variable, I want to do this task:
D2@Sketch 10 = D2@Sketch 10 + 0.005
So basically I want to take the value of the dimension, add 5mm to it and then assign it to itself. To put simply, add 5mm in an already existing value of dimension.
I am sure that there is no other way I can achieve my goal in batch processing these files.
I have very little experience with Macros. I am attaching the part file and the macro I have used previously to assign specific values to dimensions.
https://drive.google.com/drive/folders/19SiwRlHFebL4Ma_cUFh2RAG2NP9lk_y8?usp=sharing
  • $\begingroup$ SolidWorks Macro Record will capture steps you complete manually. Then you can manually make changes. $\endgroup$ Commented Oct 22, 2021 at 1:31
  • $\begingroup$ But I am not able to add the logic of adding just 5mm to a dimension. It gets passed as the value that I give in the recording session. By someway, I should be able to call the previous dimension value and then add 5mm to it. $\endgroup$ Commented Oct 25, 2021 at 19:38
This line works OK for me
Part.Parameter("D1@Sketch10").SystemValue = Part.Parameter("D1@Sketch10").SystemValue + 0.005
