-1
I'm looking for a hinge
  • that can open a maximum of 90 degrees
  • will open fully by gravity alone
  • approx 20mm wide
  • approx 50mm long each arm
  • approx 10mm thick when closed
Is this something that can be sourced? Could it be 3D printed?
  • $\begingroup$ Is there a common name for hinges that cannot open past 90 degrees? $\endgroup$
    – user195166
    Commented Oct 18, 2021 at 18:43
  • $\begingroup$ what makes you think that it would not be available? $\endgroup$
    – jsotola
    Commented Oct 18, 2021 at 18:46
Here is a full page of 90 degrees "stop" hinges for cabinets and doors. You have to browse through to find one that fits your need.
https://www.amazon.com/90-degree-stop-hinge/s?k=90+degree+stop+hinge
