I'm trying to function a 12V stepper motor(>2.5A) and five 6V servos(>3A). Are there any reliable circuits that can output both these voltages and a high output current since there will be some weight on these motors? (Servos MG996R)/(Stepper Nema 17)
Reference
    $\begingroup$ Simple answer is yes, but I think you need add some more detail to help you answer your question. Also is this a servo that is referenced in your question. jsumo.com/mg996r-servo-motor-digital $\endgroup$ Oct 16, 2021 at 12:18
  • $\begingroup$ @MahendraGunawardena yes that's the servo. regarding details, I'm going to supply this "dual dc power supply (using a single circuit)" by using an AC transformer. the circuit must be able to output two different DC voltages, 12V & 6V, and an output current of more than 6A. I was thinking something similar to the one below but this circuit only outputs 1A. circuitstoday.com/12v-5v-combo-power-supply $\endgroup$
    – Pix
    Oct 16, 2021 at 14:05
  • $\begingroup$ Are you planning to use the traditional transformer+rectifier+capacitor power supply circuit? $\endgroup$
    – user253751
    Oct 28, 2021 at 16:34
Just use 2 separate supplies (with appropriate current ratings). Or a 12V supply and a buck regulator.
There are power supplies with 2 outputs, but they are generally designed for a specific purpose, eg. PC power supplies which can provide 12V and 5V. I am not aware of any common dual supply that provides 12V and 6V.
