We performed an experiment in which we turned a bicycle on its side and placed a piece of green tap on one of the spokes. We spun the wheel and recorded the wheel spinning until it came to a complete stop. A stop watch was in the frame of the video so we could note each time that the wheel completed one revolution, so we could calculate the angular velocity.
For example, the green tape made on complete revolution in .6 seconds, and 2 revolutions in 1.31 seconds, 3 revolutions in 2.19 seconds, etc.
So my question is, how do I go about graphing this to determine if the wheel is undamped, under damped, or over damped. I am having a hard time thinking of a way to plot the data to replicate some sort of oscillation.
I may be wrong, but I calculated the arc that the wheel traveled as a function of time, synonyms to a position vs time graph, in order to view the response of my systems but clearly that doesn’t produce an oscillating graph. As time goes on, the arc distance traveled (s) is always getting larger until the wheel stops.
Examples I see, shows the displacement vs time graph of a spinning wheel but I don’t understand how can the displacement initially goes up and then come down, and then rise again and produce an isolating motion. That is easy for me to imagine for a spring mass, because the motion is literally swaying back and forth but in the case of a wheel, the distance is always getting larger.
10
    $\begingroup$ The terms underdamped and overdamped refer to a second order system. If the wheel was upright, and was slightly out of balance, it might eventually behave like a pendulum (swinging back and forth with small amplitudes), and that could be approximately a second order system. This answer to a recent question describes what you might be seeing instead... $\endgroup$
    – Pete W
    Oct 1, 2021 at 15:42
  • $\begingroup$ The bike was on its side and the wheel was spun horizontally. The wheel was parallel to the ground throughout the entire process. We are trying to determine the viscous damping of the bearing? Any ideas? $\endgroup$ Oct 1, 2021 at 15:51
  • $\begingroup$ @user15588486 PeteW's is spot on that this is not a matter of under or overdamped. Also you should put the your realquestion ("We are trying to determine the viscous damping of the bearing") in the actual post. $\endgroup$
    – NMech
    Oct 1, 2021 at 16:08
    $\begingroup$ I think you should edit your question and put in it your last 3 comments. Also put your work in (your graphs etc). $\endgroup$
    – NMech
    Oct 1, 2021 at 16:51
    $\begingroup$ 1 Is your system second order ? But, you described it with one scalar equation $a\dot{\omega}+b\omega = 0$ 2 Why did you expect an oscillating graph if the wheel was spinning in one direction and you were monitoring only the speed of the wheel ? $\endgroup$
    – AJN
    Oct 1, 2021 at 17:06
Foreword/disclaimer: This is my derivation (as I mentioned I've never seen this procedure written ), so I would appreciate any constructive feedback.
I am assuming that the viscous "damping" coefficient for this system produces a torque which is proportional to the angular velocity.
$$M(\omega(t) ) = c_t \omega(t) \tag{eq.1}$$
(this is an analogy to the viscous damping $F=c\cdot \dot{x}$.)
At any given point the rotational motion of the wheel is given by:
$$\sum M = I\cdot \alpha \tag{eq.2}$$
where:
  • $\sum M = - M_t$ is the sum to torsional moments on the wheel (I am using the minus because the torque decelerates the wheel).
  • $I$ is mass moment of inertia of the wheel
  • $\alpha = \frac{d\omega}{dt}$ is the angular acceleration of the wheel.
From eq.1, eq.2 we obtain that:
$$-c_t \omega(t) = I\cdot \frac{d\omega}{dt} $$ $$c_t dt = -I\cdot \frac{d\omega}{\omega(t) } $$
by integrating both parts we obtain:
$$\int_{t_0}^{t_1} c_t dt = -\int_{\omega_0}^{\omega_1} I\cdot \frac{d\omega}{\omega(t) } $$
$$c_t (t_1 -t_0) = -I\left[\ln \omega\right]_{\omega_0}^{\omega_1} $$ $$c_t (t_1 -t_0) = -I\ln \left(\frac{\omega_1}{\omega_0}\right)$$
Now, provided you know the mass moment of area A, you can make an estimation of the $c_t$.
numerical example
revs elapsed time lap period $ω$ $-\ln\frac{ω_ι}{ω_0}$ $c_t$
1 0.6 0.6 10.47 0 NA
2 1.31 0.71 4.79 0.780 0.39
3 2.19 0.88 2.87 1.294 0.43
assuming you have a few more numbers you can get a values for $c_t$.
Notes:
  • This assumes that $c_t$ is constant, so you should get the mean value of all the values in the $c_t$ column. (in a more advanced analysis you could assume that $c_t$ is a function of $\omega$)
  • the above values are assuming $I= 1 kg.m^2$. The actual mass moment of inertia is required to obtain proper units and values.
  • ... (probably something else I am forgetting).
  • $\begingroup$ After reading your comments , I realized that its probably some sort of exercise. Because of that I won't add the final part that's missing (it is the comments of the author). $\endgroup$
    – NMech
    Oct 1, 2021 at 17:01
  • $\begingroup$ how would I go about finding the time constant. Can I draw a tangent line to the angular displacement curve starting at time =0 and find the time that the tangent line crosses the final value on the y axis ? $\endgroup$ Oct 1, 2021 at 18:05
