Today, as I was making -for another post - the following part
Although, I managed to use a couple of ways to do the above (revolve a sketch, and b) using swept cut) I wondered how would I make grooves easily on a double curvature surface, e.g.
Something like :
double curvature
cymbal like enter image description here
dome enter image description here
(I don't know if there will be a difference, but the dome seems simpler somehow).
I would like to see how that would be done:
  • along an axis of symmetry (Seems to me simpler)
  • along an offset
Axis of symmetry Offset to axis of symmetry
enter image description here enter image description here
  • $\begingroup$ I assume, it's a requirement for the 'groove' to be normal to the surface? $\endgroup$ Sep 24, 2021 at 16:09
  • $\begingroup$ not really. (for the double curvature that might be a bit too difficult. even parallel would be fine... $\endgroup$
    – NMech
    Sep 24, 2021 at 16:14
Placeholder answer - I've made the model, but don't have time to write up how I did it just now! :)
In short - make a plane, use intersection curve to make your sweep path. The, if you want to keep normal constant, make another path to use as a guide curve.
Placeholder
  • $\begingroup$ LH is constant normal, RH is vertical $\endgroup$ Sep 24, 2021 at 16:38
