Is it possible to create a user-defined block in Simulink (and, later, XCos) that accepts a variable number of signals (I anticipate working with mainly 12 signals but not necessarily that number of signals) and outputs the integral of all the signals? The signals will be a vector from a $Ax + Bu$ signal, where $x$ is a state vector and $u$ is usually a 1D unit step function.
This is an example with 3 signals http://airvigilante194.sdf.org/Scripts/deadbeatJeff.slx I would prefer not to split the signals, integrate each of them separately, then recombine them.
(Also, if someone knows a way to quantize all the signals without splitting, quantizing individually, then recombining, that'd be great, but that may be a post for another day.)
  • $\begingroup$ By varying, do you mean varying from one run of the simulation to the next or will the number of signals vary dynamically during the simulation run ? $\endgroup$
    – AJN
    Sep 15, 2021 at 11:54
  • $\begingroup$ Matlab-Simulink integrator block already has the ability to integrate multidimensional signals without splitting them. input : Port_1 — Integrand signal : real scalar or array. $\endgroup$
    – AJN
  • $\begingroup$ @AJN Varying from one run of the simulation to the next - as I change A, B, C, and K between runs $\endgroup$ Sep 15, 2021 at 16:08
  • $\begingroup$ @AJN That's the best news I've heard all day! I'll look into that tonight and hopefully have my simulator up and running with a Jacobian matrix of a critical point of a somewhat real vector field tomorrow. $\endgroup$ Sep 15, 2021 at 16:11
(From @ANJ) Matlab-Simulink integrator block already has the ability to integrate multidimensional signals without splitting them. input : Port_1 — Integrand signal : real scalar or array.
(From me) Link is updated http://airvigilante194.sdf.org/Scripts/deadbeatJeff.slx and humming along perfectly.
