I wish to limit my flow through the output to a certain exact value. In this case to 10 lpm, what method or valve can I use to this task?
At the moment the flow keeps on fluctuating between 10.1-11.2 (seen on digital flow meter)
Any method with which the extra gas may pass out or the control over the flow is achieved more efficiently!
PS: It is located at the output of an oxygen concentrator
pic: enter image description here
Schematic: The schematic showing the placement of rotameter after the surge tank which stores oxygen. I wish to observe low fluctuations in the output oxygen flow rate, like in the range of 10+-0.2 lpm
8
  • $\begingroup$ If the gas is passing out through a constant restriction / resistance then you only need a pressure regulator. If you are trying to maintain a flow rate against a variable restriction things get more complicated. Please edit your question to give more details and, perhaps, a schematic indicating the source, the pressures, whether or not a pump is involved, whether or not it has variable speed control and details on the restrictions. "Exact" isn't an engineering specification. Use numbers to specify a tolerance. $\endgroup$
    – Transistor
    Aug 24 at 20:44
  • 3
    $\begingroup$ Can you switch from using a rotameter to a flow control valve with feedback control? $\endgroup$
    – J. Ari
    Aug 24 at 20:52
    $\begingroup$ a mass flow controller if you want to go fancy. If you just want a steady value but intend to still manually dial it in, an electronic proportional valve (with current control) is inexpensive. For the p-valve current control, results will be even better if you superimpose a slight dither waveform (~10% of full scale current amplitude, 200Hz typical for this). Adding some extra pressure drop can sometimes also be helpful to stabilize the flow $\endgroup$
    – Pete W
    Aug 24 at 22:19
    $\begingroup$ Is there any valve available that can let the extra air go out from there and just pass in the air in the range of 10 LPM. because, in this way, it will not create back-pressure in the system, right? $\endgroup$ Aug 25 at 3:59
    $\begingroup$ Use a pressure control valve. Or use pressure relief valves to maintain a max pressure. If the pressure is constant, flow should be constant. By the way, you need relief valves in this system. $\endgroup$
    – Tiger Guy
    Aug 25 at 13:39
