I was trying today to calculate the terminal velocity of a hailstones with increasing diameter and mass. I was trying to figure out if larger hailstones will have a higher impact velocity or lower.
I performed the calculation (I was a bit surprised by the end result), which I am presenting as a potential answer. I would be very happy to see if there are any improvements to this answer (if there are additional factors that I need to consider)
The terminal velocity $V_t$ will be reached when the drag coefficient is equal to the force of gravity:
$$F_{drag} = mg$$ $$C_D\frac{1}{2}\cdot \rho_{air} \cdot A \cdot V_{t}^2= m\cdot g$$
where:
  • $C_D$: is the drag coefficient (for a sphere is 0.5)
  • $\rho_{air}$ is density of the liquid the sphere is passing through (if air then 1.225 kg/m3)
  • $A$: cross-sectional area of the hailstone assuming its a sphere $\frac{\pi d^2}{4} =\pi r^2 $
  • $V_{t}$: the terminal velocity of the sphere
  • $m$: the mass of the sphere (assuming its a sphere the volume is $\frac{4}{3}\pi r^3$, and the density of the sphere is $\rho_{sphere}$)
  • $g$: the acceleration of gravity
Therefore: $$C_D\frac{1}{2} \rho_{air} \cdot \left(\pi r^2\right)\cdot V_{t}^2= \frac{4}{3}\pi r^3 \rho_{sphere}\cdot g$$
$$ V_{t}^2= \frac{4\cdot 2 \cdot\pi r^3 \rho_{sphere}\cdot g}{3C_D \rho_{air} \cdot \left(\pi r^2\right)}$$ $$ V_{t}= \sqrt{\frac{8}{3} \cdot \frac{g}{C_D } \cdot \frac{\rho_{sphere}}{\rho_{air} }\cdot r }$$
which indicates that the terminal velocity of a sphere increases proportionally to the square root of the diameter (radius).
if the buoyancy is considered then:
$$ V_{t}= \sqrt{\frac{8}{3} \cdot \frac{g}{C_D } \cdot \frac{\rho_{sphere} - \rho_{air }}{\rho_{air} }\cdot r }$$
  • $\begingroup$ Which could probably be qualitatively demonstrated by timing the fall of a rock and a grain of sand. Have to go back and generate the acceleration formula so as to drop from sufficient height to have at least the sand grain reach $V_t$ $\endgroup$ Aug 17, 2021 at 13:22
  • $\begingroup$ I'm actually working on that right now. I will probably post that as a separate question :-) $\endgroup$
    – NMech
    Aug 17, 2021 at 13:26
