My undestanding is that stress stiffening is the additional stiffness in structures when there is an applied prestressed state.
The most common example, -I know of- is how the guitar string (or a beam) changes it fundamental frequency as pretension of the guitar string increases. When you increase the tension of the string (and therefore its stress), then the fundamental frequency changes.
Parenthesis: Difference between fundamental vibration frequency of structures and strings
The fundamental frequency in the dynamics of a structure is affected by its mass and a spring constant.
In strings, Vincenzo Galilei, discovered that the velocity of propagation of a wave in a string $v$ is :
$$v=\sqrt {\frac{T}{\mu}}$$
where:
- $T$ the force of tension of the string
- $\mu$ the linear density of the string
which can be used to obtain the Mersenne law for the fundamental frequency:
$$f = \frac{1}{2L}\sqrt {\frac{T}{\mu}}$$
where:
- $T$ is the tension (in Newtons),
- $\mu$ is the linear density (that is, the mass per unit length),
- $L$ is the length of the vibrating part of the string.
What happens -in the above case - is that there is coupling between in-plane stress and transverse stiffness, which changes the vibrational behavior of the structure. This coupling is most pronounced in thin, highly stressed structures, such as cables or membranes.
In FEA, one possible implementation to account for stress stiffening, is that an additional stiffness matrix is calculated based on the previous state of the solution (for dynamic transient problem). This additional stress stiffness matrix is added to the structure stiffness matrix (which depends on geometric parameters) and the solution is updated.
