Let's say I have 2 exchangers that are completely the same, only difference being that one of them has half the number of tubes. Also let's assume the coolant is the same and has the same inlet temperature. I want the fluid to cool from 100 degrees to 70 degrees, and this works in the first exchanger. I wonder if reducing the flowrate of the fluid can make it possible for the second exchanger (with less tubes) to to the same job (to cool the fluid from 100 to 70 degrees).
Heat transfer rate is equal to:
$$Q_1=U \cdot \Delta T \cdot A$$
By reducing the number of tubes, area gets smaller and so does the heat transfer rate.
$$Q_2=U \cdot \Delta T \cdot \frac{1}{2}A= \frac{1}{2} Q_1$$
So if I want this exchanger with a halved heat transfer rate to do the same job (in terms of outlet temperatures), I assume I would need to halve the flowrate as well? Can someone tell me if I am correct here and maybe show it mathematically?
