I need help with the selection of a motor and a motor driver
I need to spin a 700g (65mm radius) round ball at 35,000 RPM. I need to bring it up to speed slowly, so I also need a motor driver/speed controller and something that tells me what the current rpm is. I have attached an image for reference.
How should I know what torque or power the motor should have?
  • $\begingroup$ Is the ball situated on the motor axis or is it located on an arm extending from the axis? $\endgroup$
    – fred_dot_u
    Jul 27, 2021 at 12:53
  • $\begingroup$ @fred_dot_u It is located on the motor axis. $\endgroup$ Jul 27, 2021 at 13:04
  • $\begingroup$ your specification is insufficient. What is needed is the acceleration you want to give the device (how long until top speed), and then we need to know what the steady state drag on the system is (what is the power to keep it going). While we're at it, the hard thing here is building a device that will rotate at such a high rate without shaking itself apart. $\endgroup$
    – Tiger Guy
    Jul 28, 2021 at 4:09
  • $\begingroup$ As Tiger guy said, the hard part will be balancing this properly. If the mass is offset by only 0.1mm at 35,000 RPM, the unbalance forces will be about 1kN. You also need to check the shaft whirling speeds, otherwise your first run will end with a bang, and a 700g sphere flying across the room looking for something it can break (and that something might be you, if you are in the way). $\endgroup$
    – alephzero
    Jul 28, 2021 at 21:37
  • $\begingroup$ You also need to realize that the maximum linear speed of the surface of the sphere will be about Mach 0.8. The aerodynamic drag will be large and the device will be the center of a small whirlwind while it is running, unless you plan to operate the device in a vacuum chamber. $\endgroup$
    – alephzero
    Jul 28, 2021 at 21:45
The text in your image could be improved by making it lighter than the background, but that's not important to the solution.
By using "torque required for rotating mass" as the search terms, I found many resources to assist your goal. Unfortunately, most of them use Imperial measurements and it appears that you're using the metric system. Not to worry, Torque for Dummies (paraphrased) has the calculations in metric.
The solution from the linked page is aimed to calculate torque for a spinning disk, not a sphere, but I suspect the mass portion of the calculation and the diameter/radius are the critical inputs.
Say that a DVD has a mass of 30 grams and a diameter of 12 centimeters. It starts at 700 revolutions per second when you first hit play and winds down to about 200 revolutions per second at the end of the DVD 50 minutes later. What’s the average torque needed to create this acceleration? You start with the torque equation:
torque equation
A DVD is a disk shape rotating around its center, which means that its moment of inertia is
moment of inertia equation
Thanks to NMech for the correction for the rotational inertial of a sphere, maintaining the original link information above.
$$\frac{2}{5} m r^2$$
The diameter of the DVD is 12 centimeters, so the radius is 6.0 centimeters. Putting in the numbers gives you the moment of inertia:
moment of inertia calculation
How about the angular acceleration,
angular acceleration question mark
Here’s the angular equivalent of the equation for linear acceleration:
angular equivalent of equation for linear acceleration
But because the angular velocity always stays along the same axis, you can consider just the components of the angular velocity and angular acceleration along this axis. They are then related by
relationship of components
First, you need to express angular velocity in radians per second, not revolutions per second. You know that the initial angular velocity is 700 revolutions per second, so in terms of radians per second, you get
more calculations
Similarly, you can get the final angular velocity this way:
still more calculations
Now you can plug the angular velocities and time into the angular acceleration formula:
hard to believe, but more calculations
The angular acceleration is negative because the angular velocity of the disk decreased. The negative acceleration then leads to a reduction in this angular velocity.
You’ve found the moment of inertia and the angular acceleration, so now you can plug those values into the torque equation:
Yep, the last of the calculations
Obviously, you'll have to replace the example values with your own. This is left as an exercise to the reader.
Note: all quoted text and formulae images directly imported from linked site.
9
  • $\begingroup$ minor improvement The moment of inertia for a solid sphere is $\frac{2}{5} m R^2$ . $\endgroup$
    – NMech
    Jul 27, 2021 at 14:06
  • $\begingroup$ the other thing I am worried is that the rpms are really high, so you might have additional friction, which might need additional torque to overcome. $\endgroup$
    – NMech
    Jul 27, 2021 at 14:08
  • $\begingroup$ @NMech, I don't know how to incorporate your comment formula into the post. If you have edit capabilities, please add that in. If not, tell me now to place it in the body. $\endgroup$
    – fred_dot_u
    Jul 27, 2021 at 15:06
    $\begingroup$ One must hope that the OP recognizes the difference between the quoted formulae and the added correction and incorporates it into the calculations. Thank you for the corrective edits. $\endgroup$
    – fred_dot_u
    Jul 27, 2021 at 16:58
  • 3
    $\begingroup$ This ignores the aerodynamic drag on the sphere and the fact that the sphere will act like a centrifugal air pump drawing air in from the "poles" and throwing it out at the "equator". The aerodynamic effects will completely swamp the torque required to accelerate the mass and inertia of the sphere. $\endgroup$
    – alephzero
    Jul 28, 2021 at 21:49
I would take a different approach to fred_dot_u.
You said you want to bring the sphere up to speed slowly, so lets assume that the acceleration doesn't matter (within reason).
I think there are 2 limiting factors you will have to take into account when choosing your motor.
  1. The friction/drag the sphere experiences at 35000 RPM.
  2. The top speed of the motor, or more specifically, the torque of the motor at 35000 RPM. This will have to be greater than the drag.
Figuring out #1 is fairly difficult. It will depend heavily on the bearings, balance, and alignment of the sphere. Realistically you will need to test it. You'll have to adapt to what you have on hand for testing but here's an example:
  • Mount the device on it's side or use pulleys so that you can spin the sphere using a dangling weight. Use a tachometer and stop watch to determine the angular acceleration due to the known force the weight applies. Use that to calculate the moment of inertia. Alternately estimate using math and the mass and position of the parts.
  • Use an airgun or some other method to spin the sphere up to 35000 RPM. Shut off the airgun, and use a stopwatch and tachometer to determine the rate of deceleration. Use this and the moment of inertia to calculate the deceleration torque.
  • Find a motor that can apply at least this much torque at 35000 RPMS
  • Note that as long as the sphere inertia is consistent throughout the procedure, it doesn't matter. For example if there's a sample that goes inside, running with or without it won't change the resulting drag value.
An alternate approach would be to simply guess, test, and iterate. A large, high KV drone motor for example might work. You'd hook that up, and test the result. If it doesn't work, you can use the motor torque/RPM chart and the speed you DID get to to make a decent guess about what motor would work. It should only take a few iterations if you take your testing data into account each time.
Also, don't forget that if you're only building one, it is often most cost and time efficient to simply choose a much more powerful motor than you think you will need. It may be more expensive, but almost certainly cheaper and faster than multiple iterations using smaller motors.
  • $\begingroup$ In addition to the factors mentioned for your #1, air drag may also be an issue. $\endgroup$
    – TimWescott
    May 21 at 6:32
