I'm working on a mechanism that requires a crank rocker - is there a formula that relates the angle (to some fixed reference; horizontal, vertical, whatever) of the driving "crank" to the angle of the driven "rocker"? I've tried to work the function out geometrically, but I'm not able to. All the other equations that I can find seem to be based on finding the limits of the system, and not any one point in time.
To illustrate; I'd like to find the relation between the angle of "s" and that of "p", relative to i.e. the horizon - something that I can, say, plot on a graph of theta(s) to theta(p). Obviously, it would be dependent on variables for the bar lengths.
Thanks.
  • $\begingroup$ Search for 3 or 4 bar chains. $\endgroup$
    Jul 21, 2021 at 18:33
  • $\begingroup$ And, yes this is possible - did something similar for a pipe with two flexible joints and varying lengths of 3 sections. Use trigonometry and work out the position of the end of s as an x,y coordinate then repeat for r and again for p. Have fun with sines, cosines and tangents also think about whether to use the included angle or not compared to the horizontal. And remember parallel lines. $\endgroup$
    Jul 21, 2021 at 18:44
  • $\begingroup$ "four-bar linkage" is also a good search term for this $\endgroup$ Jul 21, 2021 at 19:42
  • $\begingroup$ Thanks very much! I've found some papers/worksheets to look out, so I'll have fun studying them tonight. link.springer.com/content/pdf/… is good for anyone who comes across this question in the future. $\endgroup$
    – T.S
    Jul 21, 2021 at 20:41
  • $\begingroup$ Heres some worrking and several approaches $\endgroup$
    – joojaa
    Jul 22, 2021 at 12:23
I started writing this, as a solution, but I didn't end up on a neat solution (although I am certain it exists). In any case you can find a solution with numerical methods at end. If I find the neater way I will update.
Assuming that :
  • the end of bar s is point S
  • the end of bar p is point P
  • the length of bar p,q,s are respectively $L_p, L_q, L_s$
  • the angles of bars p,s are respectively $\theta_p, \theta_s$
  • the beginning of the coordinate system is at the bottom left end of bar s.
Then the coordinates for :
  • point S are:
$$\vec S = \begin{bmatrix}L_s \cos \theta_s \\L_s \sin \theta_s \\0\end{bmatrix}$$
  • point P are:
$$\vec P = \begin{bmatrix}L_q + L_p \cos \theta_p \\L_s \sin \theta_p \\0\end{bmatrix}$$
Then the distance between S and P as a vector is $$ \vec P -\vec S = \begin{bmatrix}L_q + L_p \cos \theta_p \\L_s \sin \theta_p \\0\end{bmatrix} - \begin{bmatrix}L_s \cos \theta_s \\L_s \sin \theta_s \\0\end{bmatrix} = \begin{bmatrix}L_q + L_p \cos \theta_p - L_s \cos \theta_s \\L_s \sin \theta_p -L_s \sin \theta_s \\0\end{bmatrix}$$
Therefore the distance between points P and S should be equal to the length of rod l:
$$(L_q + L_p \cos \theta_p - L_s \cos \theta_s)^2 + (L_s \sin \theta_p -L_s \sin \theta_s)^2 = L_l^2$$
if we expand and we collect all $L_p$ and $L_s$:
$$L_p^2 \left(\sin ^2(\theta_p)+\cos ^2(\theta_p)\right)+L_p (2 L_q \cos (\theta_p)+L_s (-2 \sin (\theta_p) \sin (\theta_s)-2 \cos (\theta_p) \cos (\theta_s)))+L_q^2-2 L_q L_s \cos (\theta_s)+L_s^2 \left(\sin ^2(\theta_s)+\cos ^2(\theta_s)\right) = L_l^2$$
Substituting $\left(\sin ^2(\theta_p)+\cos ^2(\theta_p)\right) = 1 =\left(\sin ^2(\theta_s)+\cos ^2(\theta_s)\right) $, simplifies the above to
$$L_p^2 +L_p (2 L_q \cos (\theta_p)+L_s (-2 \sin (\theta_p) \sin (\theta_s)-2 \cos (\theta_p) \cos (\theta_s)))+L_q^2-2 L_q L_s \cos (\theta_s)+L_s^2 = L_l^2$$
$$L_p (2 L_q \cos (\theta_p)-2 L_s ( \sin (\theta_p) \sin (\theta_s)+ \cos (\theta_p) \cos (\theta_s)))= L_l^2 - (L_p^2 - L_q^2-2 L_q L_s \cos (\theta_s)+L_s^2) $$
Also because $ \sin (\theta_p) \sin (\theta_s)+ \cos (\theta_p) \cos (\theta_s)) = \cos(\theta_p+\theta_s)$
$$L_p (2 L_q \cos (\theta_p)-2 L_s ( \cos(\theta_p+\theta_s)))= L_l^2 - (L_p^2 - L_q^2-2 L_q L_s \cos (\theta_s)+L_s^2) $$
$$L_q \cos (\theta_p)-L_s ( \cos(\theta_p+\theta_s))=\frac{1}{2 L_p }\left( L_l^2 - (L_p^2 - L_q^2-2 L_q L_s \cos (\theta_s)+L_s^2) \right) $$
At this point you can probably find a clevel trigonometrical way to solve this (I am not that good), but in this form it would be easy enough to find a numerical solution to the equation by assuming a value for $\theta_s$.
