I'm trying to get a safety factor of $n\geq2$ for the root of my snap fit beam (pic at bottom of the post).
I have gone through the calculations to get the SF at the root's edge from the geometric and material properties (using a variety of plastics), and my SF seems unnaturally small.
I don't have a lot of experience with this yet, so I wanted to check here to make sure I didn't forget something.
If someone would be kind enough to check my work, I would greatly appreciate it. Is my work incorrect, or have I just overestimated the flexibility of my materials?
Find: Safety factor at the root edge, $n_e$
(I also found SF at the root center, $n_c$, from transverse shear, but this isn't critical since stress from bending moment is zero there.)
Geometric properties
Beam length: $l=6.40~\text{mm}$
Maximum deflection: $y_{d,\text{max}}=1.20~\text{mm}$
Beam depth: $h=1.60~\text{mm}$
Beam width: $b=7.31~\text{mm}$
Root fillet radius: $r_f=0.48~\text{mm}$
Material properties (ex.)
SABIC LNP STAT-KON 5E003M: $S_y=50~\text{MPa}$, $E=9060~\text{MPa}$
(this is a fairly brittle plastic, but I got very small SFs for many other plastics as well)
Equations (beam root) $$I=\frac{1}{12}bh^3~~~~~~~~~~~~~~P=\frac{6y_dEI}{x^2(x-3l)}=-\frac{3y_{d,\text{max}}EI}{l^3}~~~~~~~~~~~~~~y_{d,\text{max}}=y_{d,x=l}$$ Equation for $P$ is based on the cantilever diagram at the bottom of the post.
Variable shear force and bending moment: $$V(x)=P~~~~~~~~~M(x)=P(l-x)$$ At $x=0$: $$V_{x=0}=-\frac{3y_{d,\text{max}}EI}{l^3}~~~~~~~~~M_{x=0}=-\frac{3y_{d,\text{max}}EI}{l^2}$$ Normal stress at the root edge: $$\sigma=\frac{My}{I}~~~~~~y=\frac{1}{2}h~~~~~~\sigma_\text{max,nom}=\frac{Mh}{2I}~~~~~~\sigma_\text{max}=K_t\sigma_\text{max,nom}$$
Stress concentration factor $K_t$ can be found by:
From my design, $K_t$ turns out to be $\approx1.40$.
Shear stress at root center: $$\tau_\text{max,nom}=\frac{3V}{2A}~~~~~~~~~~~\tau_\text{max}=\tau_\text{max,nom}$$ Von Mises stresses: $\sigma_c'=\sqrt{3\tau_\text{max}^2}$ at root center, $\sigma_e'=\sigma_\text{max}$ at root edge.
Safety factor: $$n_c=\frac{S_y}{\sigma_c'}~~~~~~~~~~~~~~~~n_e=\frac{S_y}{\sigma_e'}$$
Results (beam root)
For 5E003M, $n_e=0.056$ and $n_c=0.725$.
As you can see, these safety factors are terrible! As far as changing the material properties, I could decrease the width or depth of the beam, but the length must stay the same.
Any insight would be appreciated, thanks! :D
