I hope these exist and someone can tell me what they're called. What I'm looking for is screws to mount a PCB where the top of the screw is normal, then there's a smooth length, then a nut with a spring held in between the top of the screw to the bottom of the bolt so that, for example, if you were to press on the PCB a bit it would move a bit vertically. I'm terrible at drawing things, so I'll try with text:
=====   <Top of screw
 |\|    <Spring on smooth part of screw/bolt
 ===    <Return to normal threading
 [=]    <Nut
Anyone know?
A captive panel screw appears to be what you're talking about.
Panel screw
  • $\begingroup$ That looks like it exactly. Thanks! $\endgroup$ Commented Jul 15, 2021 at 10:53
  • $\begingroup$ But it isn't. A spring top standoff is a permanent mounted PCB standoff that can be quickly removed and reinstalled without loosing any of the parts. It is a totally rigid standoff when installed. $\endgroup$
    – Phil Sweet
    Commented Jul 15, 2021 at 20:29
It think you are looking for a spring-loaded heat sink attachment screw. These provide soft compression of a heatsink to a PCB. But you want the spring on the otherside so the mounted board can be pressed down. As far as I know, you can do that. But I'd ask the vendor to confirm it.
