I would like to export the defeatured version of my design to ANSYS.
I tried adopting the following methods but they weren't working out.
(https://forums.autodesk.com/t5/fusion-360-design-validate/how-to-export-model-after-simulation-simplify/td-p/7360686) - After simplification, I tried copying (Ctrl+C) from the existing design to a new file (Ctrl+V) which didn't seem to work. (Tried copying from the 'Model components' in the browser and pasting it into the browser in the new empty design. It did seem to load but failed in the end)
(https://www.youtube.com/watch?v=K28y5a2ortM)- I also tried exporting the simulation study as a .sdz file using the ANSYS plugin. However, the ACT wizard in ANSYS failed to open it.
The structure to be analysed is quite big and I am not in favour of defeaturing in SpaceClaim.
Please do share a workaround for this problem.
Thank you.
.x_t
and.igs
. I have expercienced many glitches with other extensions. $\endgroup$
