If water, gas and electrical cables have to pass through three (3) openings provided in the cross section shown in Figure 2, with tangible and scientific arguments specify the adequate opening for water, for gas and for electrical cables. Composite beam
    $\begingroup$ What are your arguments on this matter? Please edit them into the question. $\endgroup$
    – AJN
    Jun 13 '21 at 5:27
    $\begingroup$ This seems like homework to me. @Bernard please show what you've tried. $\endgroup$
    – NMech
    Jun 13 '21 at 5:51
    $\begingroup$ Without the specs for how much and at what pressure/voltage the three items carry, you're just guessing. Frankly, if the pipes and wires fit, who would care how they're routed, unless the electric run has specs for airspace? $\endgroup$
    – Tiger Guy
    Jun 13 '21 at 6:30
  • $\begingroup$ Welcome to Engineering! This looks like a homework question. In order for such questions to be answered in this site, we need you to add details describing the precise problem you're having. What have you tried to solve this yourself? Please edit your question to include this information. $\endgroup$
    – Wasabi
    Jun 15 '21 at 14:45
For safety reasons, the gas line shall be placed in the highest void (3), then the electrical cable in the void (2). The water pipe shall be placed in the bottom void (1).
The above arrangement is based on the thinking of - gas must not below the live electric line, for which could ignite, and live electrical line must not below the water pipe, which could leak.
In reality, this is an ill-advised/problematic application, to place all three utilities in a narrow confined space (beam, trench), that will not permit by the applicable code.
All utility lines have to be exposed, marked, accessible for maintenance.
Each has its own code of the proper location, protection from accident or intentional damage.
They have codes for repair crew set up of the work area, securing the site, providing a safe bypass for traffic or people passing by.
Inside a composite beam is not a practical place for utility lines unless the beam section is large enough to allow access and space for work, and meets the requirements for each utility line like electrical tray insulation and access, etc.
  • $\begingroup$ this could be in a factory, which would have none of these requirements unless by the insurance company. $\endgroup$
    – Tiger Guy
    Jun 13 '21 at 19:58
  • $\begingroup$ especially in a plant. safety and security and immediate access is unavoidable. $\endgroup$
    – kamran
    Jun 13 '21 at 20:31
