The given information describing a compacted soil sample is as follows:
- initial moisture content, $\omega_{init}$
- specific gravity, $G_s$
- initial volume, $V_{init}$
- initial weight, $W_{init}$
For completeness: the following information has already been determined:
- moist unit weight, $\gamma_{wet}$ using the relationship $\gamma_{wet}=\frac{W_{init}}{V_{init}}$
- dry unit weight, $\gamma_{d-init}$ using the relationship $\gamma_{d-init}=\frac{\gamma_{wet}}{1+\omega_{init}}$
- saturation, $S$ using the relationship $S=\frac{V_{water}}{V_{voids}}=\frac{V_{water}}{V_{init}-V_{solids}}=\frac{\frac{W_{init}\omega_{init}}{\gamma_w}}{V_{init}-\frac{\gamma_{d}V_{init}}{G_s\gamma_w}}$
(where $\gamma_w$ is the unit weight of water)
Problem
The problem is to determine the unit weight and the moisture content after the soil sample has been submerged and allowed to swell 5%.
The key detail for this problem is:
This compacted soil sample was then submerged in water.... After two weeks...
A soil sample that has been submerged in water for two weeks can/should be assumed** to have become saturated ($S=100\%$); i.e., all of the air in the void spaces has escaped, and the void space is now 100% filled with water.
The list of soil sample properties that can be assumed to remain constant after submersion is fairly short:
- Specific gravity, $G_s$
- Weight of solids, $W_s$
All of the other properties, such as saturation, unit weight, dry unit weight, moisture/water content, void ratio, etc. are dependent on the volume of voids and the amount of water in the soil. Both the amount of water (it was submerged) and the volume (it has swelled) have changed, so ALL of these properties will also change.
Once all of this has been recognized, the remaining portion of the problem is trivial:
- New wet unit weight: $\gamma_{new}=\gamma_{sat-new}=\frac{W_s+W_{w-new}}{V_{new}}=\frac{\gamma_{d-init}V_{init}+\gamma_w(V_{new}-V_{solids})}{V_{vew}}=\frac{\gamma_{d-init}V_{init}+\gamma_w(V_{new}-\frac{\gamma_{d}V_{init}}{G_s\gamma_w})}{V_{init}(1+5\%)}$
- New moisture content: $\omega_{new}=\frac{W_{w-new}}{W_{solids}}=\frac{\gamma_w(V_{new}-V_{solids})}{W_{solids}}=\frac{\gamma_w(V_{init}(1+5\%)-\frac{\gamma_{d}V_{init}}{G_s\gamma_w})}{\gamma_{d-init}V_{init}}$
Mechanism of Soil Swelling Behavior
The simplified effective stress equation is as follows:
$\sigma^{\prime}=\sigma-u$
Where $\sigma^{\prime}$ is the effective stress, $\sigma$ is the total stress, and $u$ is the pore water pressure.
The above equation assumes a static condition. However, when the simplified effective stress equation is imbalanced, a dynamic condition occurs and the soil must either consolidate (i.e, "shrink"), or swell. Swelling of soil occurs when the two sides of the simplified effective stress equation are not balanced, and:
- There is positive pore water pressure inside the void space of the soil, and
- the effective stress inside of the soil matrix is greater than the externally applied total stress minus the pore water pressure.
Said another way: when a soil is compacted, some amount of total stress is applied. Once equilibrium has been achieved, this total stress is associated with some combination of effective stress and pore water pressure. If the total stress changes, the previous combination of effective stress and pore water pressure within the soil matrix initially remains, but the imbalance this causes must dissipate over time. In order for the imbalance to dissipate, the voids must either increase in volume (swelling), or decrease in volume (consolidation), depending on the nature of the imbalance.
In this case, the total stress has been removed/reduced. The pore water pressure is "pushing" against the "walls" of the soil matrix pores (as always happens when $u>0$ - even when the simplified effective stress equation is balanced). Due to the reduction of total stress, there is too much internal stress (i.e., effective stress) being applied, and it must be relieved by a decrease in *pore water pressure * (i.e., an increase in volume). Or said another way, the applied total stress is not enough to stop the pores from expanding due to the pushing of the internal pore water pressure. Therefore the soil will swell until this imbalanced condition is resolved.
**The reasons for this assumption are somewhat complicated, and the assumption may not always be accurate. However, in general, the most conservative assumption for most soil mechanics/geotechnical problems is for the soil to be saturated. Therefore, if there is reason to believe the soil may be saturated, even if there is uncertainty, we almost always assume the soil is in fact saturated.
