Consider a rod with a length of 150 [mm] and a diameter of 44 [mm]. At the left boundary the rod is fixed to a wall. At the right end a torque of 1000 [N m] is applied. The remaining boundaries are free to move. As a material a S275 steel is used. Thus Young's modulus is given as $Y=210000$ [N/$mm^2$] and Poisson's ratio is $\nu=0.3$.
A reference solution for the maximal displacement suggests it should be around 0.1103 [mm] and the maximal von Mises stress should be about 103.6 [N/mm^2]. In this Solidworks tutorial the same thing is done, but with different values than the reference I used (which is also based on a Solidworks example).
The problem I have is that the finite element simulation tool I use does not have a direct way to specify a torque as a boundary condition. One can, however, specify a boundary surface pressure. I'd like to convert the given torque into a surface pressure. Here is how I did the conversion. I created a vector field that gives the direction of the pressure load in the $x$, $y$ and $z$ direction and converted the torque value into a pressure. As a vector field I used:
{0, Sin[ArcTan[y, z]], -Cos[ArcTan[y, z]]}
A plot of the vector field looks like this:
VectorPlot[{Sin[ArcTan[y, z]], -Cos[ArcTan[y, z]]}, {y, -1, 1}, {z, -1, 1}]
Then I converted the $1000$ [N m] into $1000*10^3$ [N mm]. To get a pressure I think I'd need to use something of this sort:
$$M_t / q * 1 / (\pi r^2)$$
where $M_t$ is the given torque value. I would like to convert the torque into a force by dividing the force by a length. The $q$ is the part I am uncertain about what to use. I tried $q=\sqrt{y^2 + z^2}$ such that it gives the radius to the axis but that does not give correct values. Then I divide by the area of the surface to get a pressure.
I think I am making a mistake in the conversion. If someone could point me in the right direction...
Update:
Here is a different approach: Based on this we start from
$$M_t = \frac{J_T}{r} \tau$$
where $J_T$ is the torsion constant, $r$ the radius and $\tau$ the maximum shear stress. We solve for $\tau$ to get
$$\tau = \frac{M_t r}{J_T}$$
The torsion constant can be computed with
$$J_{zz} = J_{xx} + J_{yy} = \frac{\pi r^4}{2}$$
With this approach I get a maximum displacement of $0.111035$ [mm] and a maximum von Mises stress of $104.277$ [N/mm^2], both close enough for government work.
A plot of the von Mises stress:
In principal, I think, this approach could be used for other surfaces, then one would need to compute the area moments of inertia for those surfaces.
