I'm very new to engineering and thought I'd start with some basic problems and test them out with my own constructions! I've come up with this fun problem and would love some help solving it.
Say you have two beams of wood with a thickness of 10cm.
Say you then set up a series of 13 3m tarpaulin sheets that are attached to the beams via screwed-in hooks, with 10cm between them, and placed 300kg worth of soil in each one, with a max depth of 5cm in the lowest point of the tarp.
What opposing force, in the form of grounding wire, will be needed to stop the beams from toppling over?
I have not formally studied physics since high-school, but my thinking was that there would be a torque force that needs to be opposed, my thinking is as follows:
The torque force at each point would be represented by the formula τ=rF, as the hooks would be perpendicular to the ground so sin(θ) would be 1.
We can therefore work out total torque applied to each beam with the sigma:
The problem I now face is trying to calculate the force needed for H, as well as θ. I don't understand how the torque is distributed across the beam and how that impacts the force needed to counteract it.
Is the presence of a wire like H even necessary, or can the beams be grounded with foundation to support the weight?
