I am trying to model a hovercraft and I need to obtain an air inlet flow ratio in (kg / s) of a propeller based on its dimensions (it can be the radius) and speed, is there an equation like that? Where could I find it?
  • $\begingroup$ And see the info in the comments made to you here: electronics.stackexchange.com/q/565416/152903 you now have sufficient information to continue. $\endgroup$
    May 17 at 5:06
  • $\begingroup$ You have the mass of the device - more than that in kg/s how much more is based on efficiency plus gravity. $\endgroup$
    May 17 at 9:02
