I am trying to determine the force required to vertically lift a typical traffic sign post (round, square and/or channel) out of the ground based on typical soil types at standard installation below grades depths of 30" and 36". To make the calculation simpler, assume that the post coming out of the ground is just a 4" stub and that actual sign assembly is not part of the equation.
    $\begingroup$ You forgot to ask a question. Where are you stuck? Hit the edit link below your question ... $\endgroup$
    – Transistor
    May 15 at 16:42
In general, $F = q_S * A_contact$
enter image description here enter image description here
https://hetge.com/files/PilesCapacityRefMan130403.pdf
