first of i know it seems like a homework assignment but it does not, it is calculations i need to do at work and it has been a long time since i studied this material. so I need help to calculate if a given clutch can handle a given torque but I'm not sure if my calculation are right.
what I did so far
on the left there is a motor on the right is the cluch with a connector.
ive build a FBD: enter image description here
and ended up with this eq:
$$\tau_{max} = \frac{T*r_1}{J} = \frac{2T*r_1}{\pi*r^3}=\frac{2*2.5}{\pi*(6.05*10^{-3})^3} = 7.2 [MPa]$$
but I don't know if this is the way to calculate and I don't know how to calculate if the point connecting the two diameters is strong enough.
Your calculation is generally correct .
The basic formula is:
$$\tau_{max} = \frac{T*r_1}{J}$$
Although the Torque is constant ($2.5 [Nm]$), what changes is the radii and the second moment of area.
  • For solid sections $$J_{solid} = \frac{\pi r^4}{4}$$
  • For hollow sections $$J_{hollow} = \frac{\pi \left(r_o^4 - r_i^4\right)}{4}$$
where:
  • $r_o$: the external radius
  • $r_i$: the internal radius
if you are worried for increases in stress due to the change in diameter, you can look at stress concentrations.
